Copyright © 1994-2016
This document provides detailed instructions for assembling the SG-µMD1
PCB Version 1.2.
A similar document is available for V1.0.
(There is no V1.1.) V1.0 and V1.2 are functionally equivalent for µMD1
in that they can be swapped in a system or substituted for the original
chipKit DP32 version without requiring
any hardware or software changes. Most of the differences
relate to the LED indicators, the majority of which are not
useful for µMD1 anyhow. :) But the correct assembly
procedure must be used because the layout has changed slightly,
along with some part numbers. Check the marking on the PCB to confirm
the version. All the kits should use the V1.2 PCB since I've already
populated all the V1.0 PCBs and there is only a single blank one remaining
for my reference. :)
The chipKit LEDs LED1-LED4 (on signals RB3-RB0) are still present
on SG-µMD1-V1.2 but their locations have changed as follows:
Of all the LEDs, only LD4 and LD0 are actually
needed. LD4 (LED1) flashes to indicate that the boot loader is
active. And LD0 (Power) is a key part of Smoke Test #1, below. ;-)
However, LD5 (LED3) may be used by the firmware as a heartbeat or for
status, so installing it is worthwhile. Beyond that, the other three
LEDs make the thing look like a Crhistmas tree. :) However, LD1-LD4
do monitor activity on REF, MEAS1, MEAS2, and MEAS3 so they could
conceivably have value when troubleshooting signal paths.
All components are through-hole and except as noted in the detailed
assembly procedure, should seat flush on the
PCB. They shouldn't be suspended in mid-air swinging in the breeze. :)
Most components are identified on the silk-screen and with only a few
exceptions, the label won't be obscured when the part is installed.
A low power soldering iron with narrow tip and thin (e.g., #22 AWG) rosin-core
solder will be required. DO NOT even think about attempting this without
suitable soldering equipment. It's well worth the investment. A Weller
soldering gun or propane torch will not work. :) Rosin core solder is also
essential. And while
I'm quite confident that you never make mistakes, a means of component removal
such as a de-soldering pump (e.g., SoldaPullt™) will be highly desirable.
Screwing up component removal can easily ruin the PCB and is not covered
under the unlimited limited warranty. :-)
Proper soldering technique will be such that the exposed solder on each
pad should be shiny with a concave profile. It should not be a blob and
just needs to fill the hole. Solder is not glue.
Some excess solder doesn't hurt anything
but looks unprofessional. A 10X magnifier may come in handy for
inspection. Residual rosin can be cleaned off with
isopropyl alcohol or an environmentally-friendly electronic solvent.
However, leaving the rosin alone is also acceptable (if ugly).
Total assembly time should be well under two hours for someone proficient
in fine soldering. Cutting component leads to 1/4 to 3/8 inch before
installation will simplify soldering as the long leads won't be poking
you in the face. :( :) Then trim flush after soldering.
It is recommended that the USB driver and µMD1 GUI be installed on
your PC or laptop prior to assembly so that it will be possible to perform
a "live" test as soon as the board is ready.
µMD1 is intended for use in hobbyist, experimental, research, and other
While every effort has been made to avoid this possibility, µMD1 is an
of such bugs including but not limited to damage to the wafer FAB you
picked up on eBay for $1.98 + shipping, financial loss from the use of
37 spools of ABS due to the office 3-D printer running overnight and
fabricating a part 25.4x
too large in all dimensions, or bruising to your pet's ego from any number
of causes directly or indirectly related to µMD1. ;-)
Thanks to Jan Beck for selecting the chipKIT DP32 and writing and testing
initial versions of the firmware and GUI. And for getting me interested
in actually being involved in this project. If anyone had told me
as well as slightly different versions of the firmware and a
development blog on the overall project.
And a version of the firmware providing basic readout of displacement
on any Bluetooth wireless device with a terminal APP, or with a bit
more polished presentation (though not the complete GUI) on Android devices,
may be found on Jan's Web site. See that and more under "References".
The SG-µMD1 kit of parts includes everything necessary for a 3 axis
µMD1 readout without sensors, as well as most other parts
needed to populate the PCB to be more or less equivalent to the chipKit DP32.
chipKit LED SG-uMD1-V1.2 LED Signal Location
LED1 Boot LD4 MEAS3 RB3 Near U2
LED2 LD3 MEAS2 RB2 Near U2
LED3 LD5 -- RB1 Near HDR2
LED4 LD2 MEAS1 RB0 Near U1
-- LD1 REF RB5 Near U1
-- LD0 Power VIN Near IC2
Schematic for the SG-µMD1 Version 1.2
The schematic for the SG-µMD1 Version 1.2 PCB may be found at
SG-µMD1 Version 1.2 Schematic.
This includes everything on the board. Minimally
Populated SG-µMD1 Version 1.2 Schematic includes only the
parts required for a system with up to three axes but no sensors. It
eliminates chipKIT DP32 features that are not needed for µMD1 and
is the version that will be of interest to most users. The other parts
can always be added at a later time if needed.
Click on the photo for a high resolution version which will open in a separate window for reference during assembly.
As can be seen by comparing this layout with that of the chipKIT board, most parts are in similar locations. The USB connector has moved to the bottom of the board along with its associated jumpers. The Arduino headers have moved slightly and there are now complete layout patterns for up to 3 measurement channels and locations for the environmental sensors.
For use with environmental sensors, additional components will be required that are not part of the standard SG-µMD1 kit.
The populated PCB shows all components required for a three axis system without sensors. The terminating resistors (R1,R2,R7,R8,R13,R14,R19,R20) have not been installed since their value may depend on the specific configuration. The hole spacing is such that a machine pin header strip with unused pins popped out can be installed so that resistors can be plugged into it.
IMPORTANT: All the resistors are labeled using the standard color coding as shown in the main µMD1 manual and below. Normal color vision is required to be able to identify these reliably. Even then, it is sometimes difficult to confirm the values that differ in one band or in poor lighting. And a magnifier may be required to read some markings on these and other components. If in doubt, have someone else assemble the kit or assist you.
For those not familiar with the common resistor color code (Black/0, Blown/1, Red/2, Orange/3, Yellow/4, Green/5, Blue/6, Violet/7, Gray/8, White/9), the resistors near the small IC in the upper left of the photo of the SG-µMD1 PCB shown above are 680 (blue-gray-brown or 68 with 1 zero) ohms and 330 (33 with 1 zero) ohms. The gold stripe indicates 5 percent tolerance on the value but for the use here, tolerance doesn't matter. (It's possible the resistors you use will have 4 stripes where 3 of them are the value and the 4th is the multiplier, along with one for tolerance. If in doubt confirm the value with a multimeter.) The chart below is from Digikey. (If the link decays, a Web search will readily find another one.)
The LEDs in the area for MEAS2 and MEAS3 are equivalent to the chipKit DP32 LED2 and LED1, respectively.
If only interested in running the PIC32 for other purposes, or for downloading the bootloader or other firmware using MPLAB, it's even simpler. Go to Assembly Instructions for the SG-µMD1 for MPLAB Version 1.2 PCB.
OR in the original labeled DigiKey baggies.
The parts list below assumes populating the SG-µMD1 for 3 channels with all LEDs installed. So for a single channel system, or with fewer LEDs, some parts in this list may not be present and/or there is no need to install them. The photo of the populated SG-µMD1 PCB has 3-axes but no LEDs for REF, MEAS1, and MEAS2. The LED for MEAS3 is present since it also serves as the bootloader active indicator.
Please inspect the parts closely. In particular, if not in labeled baggies, the KSP2222 / 2N3904 and MCP1700 look almost identical. Swapping them will result in failure of Smoke test #1.
Testing of the LEDs prior to installation, and then prior to soldering is recommended. They appear to be very fragile, especially if the leads are stressed while soldering. The quickest is with a source of 5 VDC and 10K ohm resistor. A couple extra LEDs have been included just in case.
The through-hole USB connector is installed at a right angle to the PCB. If you can locate a through-hole connector that installs flat on the PCB, contact me via the email links at the top of this page since that would have much preferred but I could not locate any at a reasonable cost, if at all. :)
If you would prefer one that faces sideways and are comfortable soldering an SMD connector with legs that are only 1.3 mm apart and barely accessible even with a narrow-tip soldering iron, one is also included in this kit but it is recommended that if the mounting tabs are straight, they should be to carefully bent down to fit the PCB holes. If in doubt, stick with the through-hole connector.
Note that once other parts are installed, it's virtually impossible to correct any soldering errors on the SMD connector. So carefully inspect for solder bridges and unsoldered pins.
It is recommended that the following five sets of resistors be soldered only after all have been inserted. Errors in placement will be more less traumatic if caught before soldering.
Note: The 33 pF and 0.1 µF capacitors may appear identical. Inspect their marking to identify them.
Only LD4 (which corresponds to LED1 on the chipKit board) is really needed. It flashes when the boot loader is active. LD5 is used by some versions of the firmware as a heartbeat or to indicate status so installing it is also worthwhile.
For a 2 or 3 axis system, add the following:
And if the other 3 LEDs are desired:
For sensors, refer to the schematic. :) The patterns on the PCB were designed to accommodate the most likely types, but some creativity may be needed depending on what actual parts are used. Jumpers and bypass capacitors will also be required. Pay careful attention to whether 5 V or 3.3 V is required. As a practical matter, my advice is not to bother with the sensors. An estimate of T, P, and H with the values entered into the µMD GUI will be close enough for government work. ;-)
Reference Type Part/Value Function ------------------------------------------------------------------------------- BTN1 Pushbutton SPST NO Reset BTN2 Pushbutton SPST NO Program BTN3+ Pushbutton SPST NO User C1 Capacitor 0.1 µF U1 5 V bypass C2* Capacitor 0.1 µF U2 5 V bypass C3 Capacitor 0.1 µF IC1 3.3 V bypass C4 Capacitor 4.7 µF IC1 VBUS bypass C5 Capacitor 10 µF Tant. IC1 VCAP bypass C6 Capacitor 33 pF IC1 crystal bypass C7 Capacitor 33 pF IC1 crystal bypass C8 Capacitor 0.1 µF 3.3 V bypass C9 Capacitor 0.1 µF 3.3 V bypass C10 Capacitor 4.7 µF VIN bypass C11 Capacitor 4.7 µF 3.3 V bypass IC1 IC PIC32MX250F150B-50I/S PIC32 28 pin SDIP IC2 IC MCP1703T 3.3 V regulator J1 Header 4 pin REF input connector J2 Header 4 pin MEAS1 input connector J3* Header 4 pin MEAS2 input connector J4* Header 4 pin MEAS3 input connector JP7+ Jumper block 3 pin VIN select LD0 LED 3 mm LED Power LD1 LED 3 mm LED REF LD2 LED 3 mm LED MEAS1 and chipKit LED4 LD3 LED 3 mm LED MEAS2 and chipKit LED2 LD4 LED 3 mm LED MEAS3 and chipKit LED1 LD5 LED 3 mm LED chipKit LED3 Q1 Transistor 2N3904 LD1 driver Q2 Transistor 2N3904 LD2 driver Q3 Transistor 2N3904 LD3 driver Q4 Transistor 2N3904 LD4 driver Q5 Transistor 2N3904 LD5 driver PCB1 PCB SG-µMD1-PCB Blank SG-µMD1 PCB R1 Resistor 150 ohm, 1/8 W REF termination R2 Resistor 150 ohm, 1/8 W REF termination R3 Resistor 330 ohm, 1/8 W REF 5V->3.3 V level shift R4 Resistor 680 ohm, 1/8 W REF 5V->3.3 V level shift R5 Resistor 10K ohm, 1/8 W REF LD1 LED driver base R6 Resistor 10K ohm, 1/8 W REF LD1 LED current limiting R7 Resistor 150 ohm, 1/8 W MEAS1 termination R8 Resistor 150 ohm, 1/8 W MEAS1 termination R9 Resistor 330 ohm, 1/8 W MEAS1 5V->3.3 V level shift R10 Resistor 680 ohm, 1/8 W MEAS1 5V->3.3 V level shift R11 Resistor 10K ohm, 1/8 W MEAS1 LD2 LED driver base R12 Resistor 10K ohm, 1/8 W MEAS1 LD2 LED current limiting R13* Resistor 150 ohm, 1/8 W MEAS2 termination R14* Resistor 150 ohm, 1/8 W MEAS2 termination R15* Resistor 330 ohm, 1/8 W MEAS2 5V->3.3 V level shift R16* Resistor 680 ohm, 1/8 W MEAS2 5V->3.3 V level shift R17* Resistor 10K ohm, 1/8 W MEAS2 LD3 LED driver base R18* Resistor 10K ohm, 1/8 W MEAS2 LD3 LED current limiting R19* Resistor 150 ohm, 1/8 W MEAS3 termination R20* Resistor 150 ohm, 1/8 W MEAS3 termination R21* Resistor 330 ohm, 1/8 W MEAS3 5V->3.3 V level shift R22* Resistor 680 ohm, 1/8 W MEAS3 5V->3.3 V level shift R23 Resistor 10K ohm, 1/8 W MEAS3 LD4 LED driver base R24 Resistor 10K ohm, 1/8 W MEAS3 LD4 LED current limiting R25 Resistor 10K ohm, 1/8 W LD5 LED driver base R26 Resistor 10K ohm, 1/8 W LD5 LED current limiting R27 Resistor 10K ohm, 1/8 W Power LED current limiting R30 Resistor 10K ohm, 1/8 W Program button bias network R31 Resistor 10K ohm, 1/8 W Program button bias network R32+ Resistor 10K ohm, 1/8 W User button bias network R33+ Resistor 10K ohm, 1/8 W User button bias network R34+ Resistor 51 ohm, 1/8 W P32_PGD series resistor R35+ Resistor 51 ohm, 1/8 W P32_PGC series resistor R37 Resistor 51 ohm, 1/8 W PIC32 reset R38 Resistor 10K ohm, 1/8 W PIC32 reset R39 Resistor 200 ohm, 1/8 W PIC32 reset R40 Resistor 680 ohm, 1/8 W PIC32 crystal network SKT1 Socket 28 pin, 300 mil Socket for PIC32 SKT2 Socket 8 pin, 300 mil Socket for REF/MEAS line receiver SKT3* Socket 8 pin, 300 mil Socket for MEAS2/MEAS3 line receiver SKT4+ Socket 40 pin, SIP Socket strip for HDR1,HDR2,JP6 SKT5+ Socket 40 pin, SIP Socket strip for termination resistors U1 IC UA9637 or UA9639 REF/MEAS1 line receiver U2* IC UA9637 or UA9639 MEAS2/MEAS3 line receiver USB1 Connector USB Micro B female connector X1 Crystal 8.0000 MHz PIC32 master clock
"*" denotes parts that can be omitted for a single axis system. "+" denotes parts that are not required for µMD1.
-- end V1.04a --
